주요 콘텐츠로 건너뛰기
Asus VivoBook Max X541UV-BH71-CB Battery Replacement
필요한 것
  1. Asus VivoBook Max X541UV-BH71-CB Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop upside down so the back of the laptop faces you.
  2. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 2 단계, 이미지 1/3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 2 단계, 이미지 2/3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove the ten 1.2 mm screws attached to the back cover of the laptop.
  3. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 3 단계, 이미지 1/3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 3 단계, 이미지 2/3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 3 단계, 이미지 3/3
    • Turn the laptop upright, then open the laptop so the screen faces you.
    • Use a prying tool between the keyboard and bottom grooves to partially remove the laptop backing.
    • Do not completely remove the laptop backing because there are ribbon cables connecting the two halves.
    • It is recommended to use a plastic prying tool rather than a metal prying tool because it could potentially damage the internals of the laptop.
  4. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 4 단계, 이미지 1/3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 4 단계, 이미지 2/3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 4 단계, 이미지 3/3
    • Flip the retaining flaps on both keyboard ribbon cable ZIF sockets, then carefully pull the ribbon cables out of their sockets.
    • Carefully remove the keyboard panel from the base and set it aside.
  5. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 5 단계, 이미지 1/3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 5 단계, 이미지 2/3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 5 단계, 이미지 3/3
    • Remove the two 1.2 mm screws holding the battery in place using the Phillips #00 screwdriver.
  6. Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 6 단계, 이미지 1/3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 6 단계, 이미지 2/3 Asus VivoBook Max X541UV-BH71-CB Battery Replacement: 6 단계, 이미지 3/3
    • Carefully remove the battery using a plastic opening tool.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Vivek Rana
회원 가입일: 09/11/21
169 평판
안내서 1개 작성함
York University, Team E-23, Melo-Thaiss Fall 2021 York University, Team E-23, Melo-Thaiss Fall 2021 회원
YORK-MELO-THAISS-F21SEG23
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Does anybody has a link to buy the battery replacement? Either original or generic. Thank you!
nea-k nanea - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 60
전체 시간: 2,126
