주요 콘텐츠로 건너뛰기
Asus VivoBook Q200E-BHI3T45 Battery Replacement
필요한 것
  1. Asus VivoBook Q200E-BHI3T45 Battery Replacement, Battery: 1 단계, 이미지 1/2 Asus VivoBook Q200E-BHI3T45 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 Battery Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 Battery Replacement: 3 단계, 이미지 1/2 Asus VivoBook Q200E-BHI3T45 Battery Replacement: 3 단계, 이미지 2/2
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 Battery Replacement: 4 단계, 이미지 1/2 Asus VivoBook Q200E-BHI3T45 Battery Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 Battery Replacement: 5 단계, 이미지 1/1
    • Lift and remove the battery.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Bryann Tan
회원 가입일: 09/25/16
877 평판
안내서 6개 작성하였습니다
USF Tampa, Team 16-2, Eyestone Fall 2016 USF Tampa, Team 16-2, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S16G2
3 회원들
안내서 6개 작성하였습니다
댓글 4개
Hey I need help with getting the battery out with Asus Vivo-Book E406SA
James Bruzo - 답글
hi, i need a complete case for asus vivobook Q200E. Any help please
murphy - 답글
Need help getting the battery out of my E406sa
Patrick Flynn - 답글
could you show me how to unplug the connector without breaking it?
Deng Daniel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 42
전체 시간: 15,344
