주요 콘텐츠로 건너뛰기
Asus VivoBook Q200E-BHI3T45 Fan Replacement
필요한 것
  1. Asus VivoBook Q200E-BHI3T45 Fan Replacement, Battery: 1 단계, 이미지 1/2 Asus VivoBook Q200E-BHI3T45 Fan Replacement, Battery: 1 단계, 이미지 2/2
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 Fan Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 Fan Replacement: 3 단계, 이미지 1/2 Asus VivoBook Q200E-BHI3T45 Fan Replacement: 3 단계, 이미지 2/2
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 Fan Replacement: 4 단계, 이미지 1/2 Asus VivoBook Q200E-BHI3T45 Fan Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 Fan Replacement: 5 단계, 이미지 1/1
    • Lift and remove the battery.
  6. Asus VivoBook Q200E-BHI3T45 Fan Replacement, Fan: 6 단계, 이미지 1/1
    • Gently peel off the tape from the fan.
  7. Asus VivoBook Q200E-BHI3T45 Fan Replacement: 7 단계, 이미지 1/2 Asus VivoBook Q200E-BHI3T45 Fan Replacement: 7 단계, 이미지 2/2
    • Remove five 5mm screws using a Phillips 0 screwdriver.
    • Remove the two 2mm screws with a Phillips 000 screwdriver.
  8. Asus VivoBook Q200E-BHI3T45 Fan Replacement: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Disconnect the fan's power cable by pulling upward on the pin connector with a pair of tweezers.
  9. Asus VivoBook Q200E-BHI3T45 Fan Replacement: 9 단계, 이미지 1/2 Asus VivoBook Q200E-BHI3T45 Fan Replacement: 9 단계, 이미지 2/2
    • Grab the sides of the fan assembly and remove it by lifting upwards.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Bryann Tan
회원 가입일: 09/25/16
877 평판
안내서 6개 작성하였습니다
USF Tampa, Team 16-2, Eyestone Fall 2016 USF Tampa, Team 16-2, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S16G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 582
