주요 콘텐츠로 건너뛰기
Asus VivoBook Q200E-BSI3T08 Battery Replacement
필요한 것
  1. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Battery Replacement: 3 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Battery: 4 단계, 이미지 1/1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Battery Replacement: 5 단계, 이미지 1/3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: 5 단계, 이미지 2/3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: 5 단계, 이미지 3/3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Battery Replacement: 6 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: 6 단계, 이미지 2/2
    • Now just lift the battery out of place.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Maxim
회원 가입일: 01/21/15
462 평판
안내서 1개 작성함
UWT Liner: Group 6 UWT Liner: Group 6 회원
Community
3 회원들
안내서 1개 작성하였습니다
댓글 2개
Super helpful instructions. Especially mentioning which screws were different sizes, so I knew to keep the 3 different sizes for the back cover separated and noted which sizes went back where. Many thanks!
Albert Einstein - 답글
Great guide. Thanks!
weston.fisher - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 20
전체 시간: 7,346
