주요 콘텐츠로 건너뛰기
Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement
필요한 것
  1. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: 2 단계, 이미지 1/1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: 3 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement, Cooling Fan: 4 단계, 이미지 1/1
    • Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
  5. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: 5 단계, 이미지 1/1
    • Unplug the power bus for the fan.
  6. Asus VivoBook Q200E-BSI3T08 Cooling Fan Replacement: 6 단계, 이미지 1/1
    • Lift up and remove the cooling fan from the slot.
결론
Mitchell Jackson
회원 가입일: 05/17/17
742 평판
안내서 7개 작성하였습니다
IUPUI, Team S4-G4, Wilson Summer 2017 IUPUI, Team S4-G4, Wilson Summer 2017 회원
IUPUI-WILSON-SU17S4G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 522
