주요 콘텐츠로 건너뛰기
Asus VivoBook Q200E-BSI3T08 Display Replacement
필요한 것
  1. Asus VivoBook Q200E-BSI3T08 Display Replacement, Display: 1 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Display Replacement, Display: 1 단계, 이미지 2/2
    • First open the laptop and place it so that you have access to the side of the display.
    • Next you want to place the laptop in a position where you have easy access to the display.
    • Use a metal or a plastic prying tool to split the front and back of the display.
    • Start on the side and work your way around.
  2. Asus VivoBook Q200E-BSI3T08 Display Replacement: 2 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Display Replacement: 2 단계, 이미지 2/2
    • Pull the clear plastic display down from the bottom right and left.
    • If pulled from the top you might crack the actual plastic.
  3. Asus VivoBook Q200E-BSI3T08 Display Replacement: 3 단계, 이미지 1/1
    • Remove the two 2.8mm screws on the top right and top left of the screen using a Phillips #0 screwdriver.
  4. Asus VivoBook Q200E-BSI3T08 Display Replacement: 4 단계, 이미지 1/1
    • Remove the two 2.8 screws on the bottom right and left using a Phillips #0 screwdriver.
  5. Asus VivoBook Q200E-BSI3T08 Display Replacement: 5 단계, 이미지 1/1
    • Once the screws are removed you should be able to move the display down. Be careful as there is a connection to the motherboard which will need to be removed.
  6. Asus VivoBook Q200E-BSI3T08 Display Replacement: 6 단계, 이미지 1/1
    • Here is a picture of the connection that needs to be removed to free the display.
    • Pull connection from the plastic on the sides not the wires as these are fragile.
  7. Asus VivoBook Q200E-BSI3T08 Display Replacement: 7 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Display Replacement: 7 단계, 이미지 2/2
    • Once this connection is removed here's what that should look.
  8. Asus VivoBook Q200E-BSI3T08 Display Replacement: 8 단계, 이미지 1/1
    • Remove display and place your new one in it's place.
결론
Mitchell Jackson
회원 가입일: 05/17/17
742 평판
안내서 7개 작성하였습니다
IUPUI, Team S4-G4, Wilson Summer 2017 IUPUI, Team S4-G4, Wilson Summer 2017 회원
IUPUI-WILSON-SU17S4G4
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
You are suppose to remove the hinge/screen assembly from the laptop chasis before starting step 1, if you don't you will break the digitizer author please fix the guide
Nicholas Chan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,855
