주요 콘텐츠로 건너뛰기
Asus VivoBook Q200E-BSI3T08 Keyboard Replacement
필요한 것
  1. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 2 단계, 이미지 1/1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 3 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Motherboard: 4 단계, 이미지 1/1
    • Locate the motherboard under the cooling fan.
  5. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 5 단계, 이미지 1/1
    • Unscrew the two 5.9mm screws on the PCB board with a Phillips #0 screwdriver.
  6. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 6 단계, 이미지 1/1
    • Remove the PCB board from the motherboard.
  7. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 7 단계, 이미지 1/1
    • Unscrew the four 5.9mm hard drive bracket screws with a Phillips #0 screwdriver.
  8. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 8 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 8 단계, 이미지 2/2
    • Unscrew the four 5.9mm screws with a Phillips #0 screwdriver.
    • Next, carefully lift the LAN bracket out of the slot.
  9. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 9 단계, 이미지 1/1
    • Remove the five 5.9mm screws holding the motherboard in place with a Phillips #0 screwdriver.
    • Remove the five 3.5mm screws holding the motherboard with a Phillips #00 screwdriver.
  10. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 10 단계, 이미지 1/1
    • Carefully lift the motherboard up out of the slot.
  11. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 11 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 11 단계, 이미지 2/2
    • Locate and unplug the power bus from the motherboard.
    • The motherboard can now be replaced.
  12. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Battery: 12 단계, 이미지 1/1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  13. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 13 단계, 이미지 1/3 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 13 단계, 이미지 2/3 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 13 단계, 이미지 3/3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  14. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 14 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 14 단계, 이미지 2/2
    • Now just lift the battery out of place.
  15. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Trackpad: 15 단계, 이미지 1/1
    • Disconnect the small blue TP(trackpad) labeled data bus.
  16. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 16 단계, 이미지 1/1
    • Identify the ten 2.94mm screws on the metal bracket.
  17. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 17 단계, 이미지 1/1
    • Unscrew the ten 2.94mm screws with the Philips #00 Head.
  18. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 18 단계, 이미지 1/1
    • Remove all of the metallic tape holding the metal bracket to the components surrounding it.
  19. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 19 단계, 이미지 1/1
    • Lift the metal bracket away from the laptop.
  20. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 20 단계, 이미지 1/1
    • Unscrew the four 3.5mm screws with Phillips #00 Head.
    • This black plastic panel holds the trackpad in place.
  21. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 21 단계, 이미지 1/1
    • Lift the trackpad up from the laptop and slide it out of the housing.
  22. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Cooling Fan: 22 단계, 이미지 1/1
    • Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
  23. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 23 단계, 이미지 1/1
    • Unplug the power bus for the fan.
  24. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 24 단계, 이미지 1/1
    • Lift up and remove the cooling fan from the slot.
  25. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Keyboard: 25 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement, Keyboard: 25 단계, 이미지 2/2
    • Next, unscrew the two 4.9mm hinge screws with a Phillips #00 screwdriver.
  26. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 26 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 26 단계, 이미지 2/2
    • Remove the ten 4.9mm screws holding the metal keyboard panel in place, using a Phillips #00 screwdriver.
    • Carefully lift the metal keyboard panel out of the slot.
  27. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 27 단계, 이미지 1/1
    • Pull the display hinges back in order to remove the metal keyboard panel.
  28. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 28 단계, 이미지 1/1
    • Carefully pry and loosen the keyboard from the slot.
  29. Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 29 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Keyboard Replacement: 29 단계, 이미지 2/2
    • Carefully lift the keyboard out of the slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mitchell Jackson
회원 가입일: 05/17/17
742 평판
안내서 7개 작성하였습니다
IUPUI, Team S4-G4, Wilson Summer 2017 IUPUI, Team S4-G4, Wilson Summer 2017 회원
IUPUI-WILSON-SU17S4G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 2,240
