주요 콘텐츠로 건너뛰기
Asus VivoBook Q200E-BSI3T08 Trackpad Replacement
필요한 것
  1. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 2 단계, 이미지 1/1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 3 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Battery: 4 단계, 이미지 1/1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 5 단계, 이미지 1/3 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 5 단계, 이미지 2/3 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 5 단계, 이미지 3/3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 6 단계, 이미지 1/2 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 6 단계, 이미지 2/2
    • Now just lift the battery out of place.
  7. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Trackpad: 7 단계, 이미지 1/1
    • Disconnect the small blue TP(trackpad) labeled data bus.
  8. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 8 단계, 이미지 1/1
    • Identify the ten 2.94mm screws on the metal bracket.
  9. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 9 단계, 이미지 1/1
    • Unscrew the ten 2.94mm screws with the Philips #00 Head.
  10. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 10 단계, 이미지 1/1
    • Remove all of the metallic tape holding the metal bracket to the components surrounding it.
  11. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 11 단계, 이미지 1/1
    • Lift the metal bracket away from the laptop.
  12. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 12 단계, 이미지 1/1
    • Unscrew the four 3.5mm screws with Phillips #00 Head.
    • This black plastic panel holds the trackpad in place.
  13. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: 13 단계, 이미지 1/1
    • Lift the trackpad up from the laptop and slide it out of the housing.
결론
Mitchell Jackson
회원 가입일: 05/17/17
742 평판
안내서 7개 작성하였습니다
IUPUI, Team S4-G4, Wilson Summer 2017 IUPUI, Team S4-G4, Wilson Summer 2017 회원
IUPUI-WILSON-SU17S4G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 578
