주요 콘텐츠로 건너뛰기
Asus VivoBook Q302LA-BHI3T09 Display Replacement
필요한 것
  1. Asus VivoBook Q302LA-BHI3T09 Display Replacement, Display: 1 단계, 이미지 1/2 Asus VivoBook Q302LA-BHI3T09 Display Replacement, Display: 1 단계, 이미지 2/2
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
  2. Asus VivoBook Q302LA-BHI3T09 Display Replacement: 2 단계, 이미지 1/2 Asus VivoBook Q302LA-BHI3T09 Display Replacement: 2 단계, 이미지 2/2
    • Insert the flat edge of the opening tool in between the back casing to remove the back casing.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Display Replacement: 3 단계, 이미지 1/2 Asus VivoBook Q302LA-BHI3T09 Display Replacement: 3 단계, 이미지 2/2
    • Using the JIS #0 Screwdriver, remove the five 3.0 mm screws that hold down the hard drive casing.
  4. Asus VivoBook Q302LA-BHI3T09 Display Replacement: 4 단계, 이미지 1/3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: 4 단계, 이미지 2/3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: 4 단계, 이미지 3/3
    • Lift the hard drive up and remove the power supply cable connected to it.
    • Make sure to pull on the plastic head and not the actual wires to prevent tearing them.
  5. Asus VivoBook Q302LA-BHI3T09 Display Replacement: 5 단계, 이미지 1/2 Asus VivoBook Q302LA-BHI3T09 Display Replacement: 5 단계, 이미지 2/2
    • Disconnect the white and black wires attached to the Wi-Fi chip.
  6. Asus VivoBook Q302LA-BHI3T09 Display Replacement: 6 단계, 이미지 1/3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: 6 단계, 이미지 2/3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: 6 단계, 이미지 3/3
    • Remove the two adapters connecting the display to the motherboard by pulling the black plastic straps directly upwards.
  7. Asus VivoBook Q302LA-BHI3T09 Display Replacement: 7 단계, 이미지 1/3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: 7 단계, 이미지 2/3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: 7 단계, 이미지 3/3
    • Use the JIS #0 screwdriver to remove the five 5.0 mm screws connecting the display to the rest of the laptop.
결론
Deric Wright
회원 가입일: 02/14/18
636 평판
안내서 3개 작성하였습니다
USF Tampa, Team S5-G5, Eyestone Spring 2018 USF Tampa, Team S5-G5, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 263
