주요 콘텐츠로 건너뛰기
Asus VivoBook S200E-RHI3T73 Screen Replacement
필요한 것
  1. Asus VivoBook S200E-RHI3T73 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the five black 80mm Phillips #0 screws.
    • Remove the four black 50mm Phillips #0 screws.
  2. Asus VivoBook S200E-RHI3T73 Screen Replacement: 2 단계, 이미지 1/1
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  3. Asus VivoBook S200E-RHI3T73 Screen Replacement: 3 단계, 이미지 1/1
    • Use a metal spudger to remove the clear screen protector from its backing.
    • Apply ample force along the bottom of the screen protector.
  4. Asus VivoBook S200E-RHI3T73 Screen Replacement: 4 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the four 2mm silver screws located at each of the four corners of the screen.
  5. Asus VivoBook S200E-RHI3T73 Screen Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Gently lift the screen up and over.
    • Use tweezers to remove the EX2 LVDS connector cable that connects the screen and the laptop.
    • Remove the screen.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Shilo Stuart
회원 가입일: 04/12/17
586 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 2,068
