주요 콘텐츠로 건너뛰기
Asus VivoBook S200E-RHI3T73 Touchpad Replacement
필요한 것
  1. Asus VivoBook S200E-RHI3T73 Touchpad Replacement, Touchpad: 1 단계, 이미지 1/2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement, Touchpad: 1 단계, 이미지 2/2
    • In order to remove the back lid, you must lay the laptop down with the lid closed and remove the screws with a Phillips #0 screwdriver.
    • There are five 80mm screws.
    • There are four 50mm screws.
    • Pull the back lid off of the laptop using your fingers.
  2. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: 2 단계, 이미지 1/2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: 2 단계, 이미지 2/2
    • There should be a total of twelve 50mm screws when removing the battery.
    • The battery does not have to be fully removed for this step, however the screws must be taken out and the battery lifted.
  3. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: 3 단계, 이미지 1/2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: 3 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove the six screws attached to the silver panel.
    • Disconnect the LED ribbon wires using a spudger to lift the clamp.
  4. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: 4 단계, 이미지 1/2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: 4 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the four screws on the silver panel.
    • Using a spudger, gently lift the silver ground strips off of the touch pad.
    • Pull the touch pad up and towards the battery to remove it from the laptop.
결론
Katherine Nasci
회원 가입일: 04/01/19
124 평판
안내서 1개 작성함
IUPUI, Team S9-G9, Wilson Spring 2019 IUPUI, Team S9-G9, Wilson Spring 2019 회원
IUPUI-WILSON-S19S9G9
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 16
전체 시간: 743
