소개
In the case that your Laptop’s Touchpad stops working, you may need to replace it. This guide shows you how to replace the Touchpad in just a few simple steps.
필요한 것
In order to remove the back lid, you must lay the laptop down with the lid closed and remove the screws with a Phillips #0 screwdriver.
There are five 80mm screws.
There are four 50mm screws.
Pull the back lid off of the laptop using your fingers.
거의 끝나갑니다!
결론
