주요 콘텐츠로 건너뛰기
Asus VivoBook X202E-DB21T Battery Replacement
필요한 것
  1. Asus VivoBook X202E-DB21T Battery Replacement, Battery: 1 단계, 이미지 1/2 Asus VivoBook X202E-DB21T Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Battery Replacement: 2 단계, 이미지 1/2 Asus VivoBook X202E-DB21T Battery Replacement: 2 단계, 이미지 2/2
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Battery Replacement: 3 단계, 이미지 1/2 Asus VivoBook X202E-DB21T Battery Replacement: 3 단계, 이미지 2/2
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Battery Replacement: 4 단계, 이미지 1/1
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Battery Replacement: 5 단계, 이미지 1/1
    • Remove the battery from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
John Thomas
회원 가입일: 01/13/19
756 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 15
전체 시간: 371
