소개
The display is used to display images sent to it by the motherboard. This guide will only show full display replacement, as the display is made of several parts glued together. However, to replace a component of the screen, the display must be removed in its entirety.
필요한 것
Flip the device such that the labels are on top.
Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
Use the same screwdriver to remove the four 5mm screws in the front.
Use the same screwdriver to remove the single 9mm screw in the center.
