주요 콘텐츠로 건너뛰기
Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly
필요한 것
  1. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly, Keyboard: 1 단계, 이미지 1/1
    • Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
  2. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: 2 단계, 이미지 1/1
    • Flip the laptop over so the back panel is displayed.
  3. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: 3 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
    • Remove the two battery screws (15.6 mm)
    • Two top corner screws (12.5 mm)
    • Six case screws (9.7mm)
  4. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: 4 단계, 이미지 1/1
    • Flip the laptop back over and open it, revealing the screen and keyboard.
  5. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: 5 단계, 이미지 1/1
    • Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
    • It is recommended to break the seal of the case starting at the upper corners closest to the display monitor .
  6. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: 6 단계, 이미지 1/1
    • Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
  7. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly, Battery: 7 단계, 이미지 1/1
    • Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
    • The batteries should all be connected to one another and come out of the device as a single unit.
    • Be careful not to rip any of the black plastic covering the batteries. Exposed battery parts can lead to explosions. If the case is ripped, re-wrap them, or properly dispose of them. Do not reuse them.
  8. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly, Disk Drive: 8 단계, 이미지 1/1
    • The Disk Drive is located within the upper right hand corner of the laptop.
  9. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: 9 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the two screws (5.6 mm) around the disc drive.
    • Note which screws go where. The two smaller screws fasten onto the disc drive, while the three larger screws secure the drive on the outside.
  10. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: 10 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the two screws (2.7 mm) on the side of the disc drive fastener.
  11. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: 11 단계, 이미지 1/1
    • After removing the seven screws, lift the metal fastener from the disc drive with the plastic opening tool.
  12. Asus VivoBook X540SA-BPD0602V Disc Drive Disassembly: 12 단계, 이미지 1/1
    • Slide the disc drive to the right, removing it from the laptop case.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jessica Browne
회원 가입일: 10/18/17
978 평판
안내서 6개 작성하였습니다
USF Tampa, Team S1-G111, Cagle Fall 2017 USF Tampa, Team S1-G111, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G111
5 회원들
안내서 14개 작성하였습니다
댓글 한 개
I have a Asus X540U can I replace the ODD with a HDD SSD Caddy?
Rey Antipino Jr. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 27
전체 시간: 1,134
