소개
In this guide you will learn how to replace your Asus Vivobook X540SA-BPD0602V's motherboard. A damaged motherboard will lead to a lack of a digital display and the inability to use your device.
필요한 것
Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
The Hard Drive is located in the bottom right hand corner. It should be the device covered in black foam.
Using the blue plastic opening tool in the iFixit tool kit, slide the hard drive to the right to remove it from the case.
Looks like the author neglected to describe removing the hard disk from the hard drive caddy. I assume I assume there are 4 screws, 2 on each side. If the reader never replaced a laptop hard drive, they may think the laptop has a special hard drive, not a standard hard drive. Thank you for the well-done Jessica.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
Hello could you tell me were is the battery of the motherboard?
sajo.in.fo - 답글
There isn't one, it pulls CMOS/BIOS power from the main battery.
