소개
If your tablet's battery will not hold a charge, this guide will show you how to replace the battery in 13 quick and easy steps.
필요한 것
Remove the tablet from the attached keyboard.
To remove the keyboard, simply depress the switch on the left side of the screen and pull the tablet portion off.
이 단계에 사용된 도구:Tweezers$4.99
Rotate the Tablet clockwise, so that the motherboard is facing away from you.
Remove the eleven 0.79 mm #000 screws around the motherboard with the Phillips #000 screwdriver.
Remove the two wire connection on the right side of the tablet with the pointed precision tweezers.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
Hi...Im trying to disconnect battery and reconnect like pics above to try a reset from black screen of death after updates...I have black screen..it was working fine until then..now I dont even get a power light to show its charging????
