주요 콘텐츠로 건너뛰기
Asus VivoTab RT TF600T Speaker Replacement
필요한 것
  1. Asus VivoTab RT TF600T Speaker Replacement, Speaker: 1 단계, 이미지 1/3 Asus VivoTab RT TF600T Speaker Replacement, Speaker: 1 단계, 이미지 2/3 Asus VivoTab RT TF600T Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Make sure the tablet is turned off.
    • Remove the tablet from the attached keyboard.
    • To remove the keyboard, simply depress the switch on the left side of the screen and pull the tablet portion off.
  2. Asus VivoTab RT TF600T Speaker Replacement: 2 단계, 이미지 1/3 Asus VivoTab RT TF600T Speaker Replacement: 2 단계, 이미지 2/3 Asus VivoTab RT TF600T Speaker Replacement: 2 단계, 이미지 3/3
    • Rotate the device 180°, and remove the two 1.59 mm #000 screws at the bottom of the device.
    • Use the Phillips screwdriver size PH000 to remove the two 1.59 mm #000 screws.
  3. Asus VivoTab RT TF600T Speaker Replacement: 3 단계, 이미지 1/2 Asus VivoTab RT TF600T Speaker Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool to help detach the screen from the back panel.
    • Insert the plastic opening tool into the bottom right corner and gently start to pry off the screen.
    • Once the screen begins to separate from the body of the device, start working the tool around the outer edges until the entire screen becomes detached.
  4. Asus VivoTab RT TF600T Speaker Replacement: 4 단계, 이미지 1/2 Asus VivoTab RT TF600T Speaker Replacement: 4 단계, 이미지 2/2
    • Now that the screen is completely detached, lay the back panel flat on a smooth surface.
    • Lift the screen to view the inside of the tablet.
  5. Asus VivoTab RT TF600T Speaker Replacement: 5 단계, 이미지 1/2 Asus VivoTab RT TF600T Speaker Replacement: 5 단계, 이미지 2/2
    • Before disconnecting the display cables, turn off the switch labeled DIP; this switch is used to de-energize the system.
    • The battery is connected to the motherboard. To avoid any short circuiting of the device, you must place the switch labeled DIP to OFF.
  6. Asus VivoTab RT TF600T Speaker Replacement: 6 단계, 이미지 1/3 Asus VivoTab RT TF600T Speaker Replacement: 6 단계, 이미지 2/3 Asus VivoTab RT TF600T Speaker Replacement: 6 단계, 이미지 3/3
    • Remove the yellow tape covering the end of the cables.
  7. Asus VivoTab RT TF600T Speaker Replacement: 7 단계, 이미지 1/2 Asus VivoTab RT TF600T Speaker Replacement: 7 단계, 이미지 2/2
    • After lifting the yellow tape, you should be able to see a white strip. The white strip is actually a lever.
    • Use the plastic opening tool to push in the levers.
  8. Asus VivoTab RT TF600T Speaker Replacement: 8 단계, 이미지 1/3 Asus VivoTab RT TF600T Speaker Replacement: 8 단계, 이미지 2/3 Asus VivoTab RT TF600T Speaker Replacement: 8 단계, 이미지 3/3
    • With all three white levers pushed in, gently pull on each display cable until the cable disconnects.
  9. Asus VivoTab RT TF600T Speaker Replacement: 9 단계, 이미지 1/1
    • Lift the screen upwards to remove.
  10. Asus VivoTab RT TF600T Speaker Replacement: 10 단계, 이미지 1/2 Asus VivoTab RT TF600T Speaker Replacement: 10 단계, 이미지 2/2
    • Turn the tablet clockwise, so the speaker is facing the right.
    • Use the nylon or metal spudger to pry the battery from the back panel.
  11. Asus VivoTab RT TF600T Speaker Replacement: 11 단계, 이미지 1/2 Asus VivoTab RT TF600T Speaker Replacement: 11 단계, 이미지 2/2
    • Remove two 0.79 mm #00 screws from the speaker with a Phillips screwdriver size #00.
  12. Asus VivoTab RT TF600T Speaker Replacement: 12 단계, 이미지 1/2 Asus VivoTab RT TF600T Speaker Replacement: 12 단계, 이미지 2/2
    • Remove the speaker with the plastic opening tool.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joseph C Reneau
회원 가입일: 10/15/15
276 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 1-2, Blackburne Fall 2015 Sam Houston State, Team 1-2, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 249
