주요 콘텐츠로 건너뛰기
Asus VivoTab RT TF600T Webcam Replacement
필요한 것
  1. Asus VivoTab RT TF600T Webcam Replacement, Webcam: 1 단계, 이미지 1/3 Asus VivoTab RT TF600T Webcam Replacement, Webcam: 1 단계, 이미지 2/3 Asus VivoTab RT TF600T Webcam Replacement, Webcam: 1 단계, 이미지 3/3
    • Make sure the tablet is turned off.
    • Remove the tablet from the attached keyboard.
    • To remove the keyboard, simply depress the switch on the left side of the screen and pull the tablet portion off.
  2. Asus VivoTab RT TF600T Webcam Replacement: 2 단계, 이미지 1/3 Asus VivoTab RT TF600T Webcam Replacement: 2 단계, 이미지 2/3 Asus VivoTab RT TF600T Webcam Replacement: 2 단계, 이미지 3/3
    • Rotate the device 180°, and remove the two 1.59 mm screws at the bottom of the device.
    • Use the Phillips screwdriver size #000 to remove the two 1.59 mm screws.
  3. Asus VivoTab RT TF600T Webcam Replacement: 3 단계, 이미지 1/2 Asus VivoTab RT TF600T Webcam Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool to help detach the screen from the back panel.
    • Insert the plastic opening tool into the bottom right corner and gently start to pry off the screen.
    • Once the screen begins to separate from the body of the device, start working the tool around the outer edges until the entire screen becomes detached.
  4. Asus VivoTab RT TF600T Webcam Replacement: 4 단계, 이미지 1/2 Asus VivoTab RT TF600T Webcam Replacement: 4 단계, 이미지 2/2
    • Now that the screen is completely detached, lay the back panel flat on a smooth surface.
    • Lift the screen to view the inside of the tablet.
  5. Asus VivoTab RT TF600T Webcam Replacement: 5 단계, 이미지 1/2 Asus VivoTab RT TF600T Webcam Replacement: 5 단계, 이미지 2/2
    • Before disconnecting the display cables, refer to the image to turn off the switch labeled DIP; this switch is used to de-energize the system.
    • The battery is connected to the motherboard. To avoid any short circuiting of the device, you must place the switch labeled DIP to OFF.
  6. Asus VivoTab RT TF600T Webcam Replacement: 6 단계, 이미지 1/3 Asus VivoTab RT TF600T Webcam Replacement: 6 단계, 이미지 2/3 Asus VivoTab RT TF600T Webcam Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Rotate the Tablet clockwise, so that the webcam is facing away from you.
    • Gently lift the webcam out of its socket with the precision tweezers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brandi Mathews
회원 가입일: 10/13/15
140 평판
안내서 1개 작성함
Sam Houston State, Team 1-2, Blackburne Fall 2015 Sam Houston State, Team 1-2, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 231
