주요 콘텐츠로 건너뛰기
Asus VivoTab Smart Camera Replacement
필요한 것
  1. Asus VivoTab Smart Camera Replacement, Motherboard: 1 단계, 이미지 1/3 Asus VivoTab Smart Camera Replacement, Motherboard: 1 단계, 이미지 2/3 Asus VivoTab Smart Camera Replacement, Motherboard: 1 단계, 이미지 3/3
    • Power off the device before you begin disassembly.
    • Place the device face down on a flat surface.
    • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
  2. Asus VivoTab Smart Camera Replacement: 2 단계, 이미지 1/3 Asus VivoTab Smart Camera Replacement: 2 단계, 이미지 2/3 Asus VivoTab Smart Camera Replacement: 2 단계, 이미지 3/3
    • Unplug the ribbon that connects to the camera by pulling outward on it with tweezers.
    • Remove the silver plate that sits on top of the camera lens.
  3. Asus VivoTab Smart Camera Replacement: 3 단계, 이미지 1/3 Asus VivoTab Smart Camera Replacement: 3 단계, 이미지 2/3 Asus VivoTab Smart Camera Replacement: 3 단계, 이미지 3/3
    • Use tweezers to grab the speaker cable near the white plug and pull to disconnect it.
  4. Asus VivoTab Smart Camera Replacement: 4 단계, 이미지 1/2 Asus VivoTab Smart Camera Replacement: 4 단계, 이미지 2/2
    • Gently pull outward on the ribbon to with tweezers to disconnect it.
  5. Asus VivoTab Smart Camera Replacement: 5 단계, 이미지 1/3 Asus VivoTab Smart Camera Replacement: 5 단계, 이미지 2/3 Asus VivoTab Smart Camera Replacement: 5 단계, 이미지 3/3
    • Peel back the tape covering the ribbons.
  6. Asus VivoTab Smart Camera Replacement: 6 단계, 이미지 1/3 Asus VivoTab Smart Camera Replacement: 6 단계, 이미지 2/3 Asus VivoTab Smart Camera Replacement: 6 단계, 이미지 3/3
    • Unplug the 3 ribbons by pulling outward on them with a pair of tweezers.
  7. Asus VivoTab Smart Camera Replacement: 7 단계, 이미지 1/3 Asus VivoTab Smart Camera Replacement: 7 단계, 이미지 2/3 Asus VivoTab Smart Camera Replacement: 7 단계, 이미지 3/3
    • Remove two 2.7 mm Phillips #00 screws holding down the pressure plate.
    • Use tweezers to lift back the battery connector, which is located directly under the pressure plate.
  8. Asus VivoTab Smart Camera Replacement: 8 단계, 이미지 1/2 Asus VivoTab Smart Camera Replacement: 8 단계, 이미지 2/2
    • Remove seven 3.7 mm Phillips #00 screws.
    • Remove one 2.7 mm Phillips #00 screw.
  9. Asus VivoTab Smart Camera Replacement: 9 단계, 이미지 1/2 Asus VivoTab Smart Camera Replacement: 9 단계, 이미지 2/2
    • Slide the tweezers under the motherboard and lift up to remove the motherboard.
  10. Asus VivoTab Smart Camera Replacement, Camera: 10 단계, 이미지 1/1
    • Flip the motherboard over and lay it flat on a surface
  11. Asus VivoTab Smart Camera Replacement: 11 단계, 이미지 1/2 Asus VivoTab Smart Camera Replacement: 11 단계, 이미지 2/2
    • Use tweezers to gently lift and remove the camera from the motherboard.
결론
Zach Hatten
회원 가입일: 10/06/16
548 평판
안내서 4개 작성하였습니다
USF Tampa, Team 2-4, Sullivan Fall 2016 USF Tampa, Team 2-4, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 308
