주요 콘텐츠로 건너뛰기
Asus VivoTab Smart Speaker Replacement
필요한 것
  1. Asus VivoTab Smart Speaker Replacement, Speaker: 1 단계, 이미지 1/3 Asus VivoTab Smart Speaker Replacement, Speaker: 1 단계, 이미지 2/3 Asus VivoTab Smart Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Power off the device before you begin disassembly.
    • Place the device face down on a flat surface.
    • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
  2. Asus VivoTab Smart Speaker Replacement: 2 단계, 이미지 1/3 Asus VivoTab Smart Speaker Replacement: 2 단계, 이미지 2/3 Asus VivoTab Smart Speaker Replacement: 2 단계, 이미지 3/3
    • Take care not to break the speaker wire when unplugging it from the device.
    • Carefully unplug the speaker wire from the device by grabbing the wire near the white plug with tweezers and pulling gently.
  3. Asus VivoTab Smart Speaker Replacement: 3 단계, 이미지 1/2 Asus VivoTab Smart Speaker Replacement: 3 단계, 이미지 2/2
    • Remove two 2.7 mm Phillips #00 screws.
    • Remove two 3.7 mm Phillips #00 screws.
  4. Asus VivoTab Smart Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the speaker from the device by lifting up on it.
결론
Zach Hatten
회원 가입일: 10/06/16
548 평판
안내서 4개 작성하였습니다
USF Tampa, Team 2-4, Sullivan Fall 2016 USF Tampa, Team 2-4, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 324
