주요 콘텐츠로 건너뛰기
Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement
필요한 것
  1. Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 1개 중 1개
    • Remove the 11 Philips #00 screws from the underside of the device.
    • Four 12mm screws.
    • Three 10mm screws.
    • Four 7mm screws.
  2. Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement: 2 단계, 이미지 1개 중 1개
    • With the laptop open, use a opening tool to detach the keyboard from the laptops body. Lift the keyboard up slowly as to not damage the ribbon cables that connect from the keyboard.
  3. Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 1개 Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully pull out the three ribbon connectors at the front of the device.
    • After the three small cables are disconnected, the keyboard can be lifted up more to allow for easier access to the larger fourth ribbon cable.
  4. Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement: 4 단계, 이미지 1개 중 1개
    • Just below the fan is the wi-fi card. Disconnect the black and white antenna wires by applying a gentle upward force.
  5. Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the 3mm Phillips #00 screw securing the card in place.
  6. Asus Vivobook K570UD-DS74 Wi-Fi Card Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pull the card to the side and it will come out of its socket. The wi-fi card can now be replaced.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 32
전체 시간: 1,426
