주요 콘텐츠로 건너뛰기
Asus Vivobook Max X541SA-PD0703X Battery Replacement
필요한 것
  1. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Battery Replacement: 3 단계, 이미지 3개 중 1개 Asus Vivobook Max X541SA-PD0703X Battery Replacement: 3 단계, 이미지 3개 중 2개 Asus Vivobook Max X541SA-PD0703X Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Battery Replacement: 4 단계, 이미지 3개 중 1개 Asus Vivobook Max X541SA-PD0703X Battery Replacement: 4 단계, 이미지 3개 중 2개 Asus Vivobook Max X541SA-PD0703X Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Battery Replacement: 6 단계, 이미지 2개 중 1개 Asus Vivobook Max X541SA-PD0703X Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
  8. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Disc Drive: 8 단계, 이미지 1개 중 1개
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
  9. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Motherboard: 9 단계, 이미지 2개 중 1개 Asus Vivobook Max X541SA-PD0703X Battery Replacement, Motherboard: 9 단계, 이미지 2개 중 2개
    • Remove the three 6mm Phillips #0 screws from the fan shroud.
    • Remove the shroud from the motherboard.
  10. Asus Vivobook Max X541SA-PD0703X Battery Replacement: 10 단계, 이미지 1개 중 1개
    • Pull the metal casing to the right.
    • Be careful when pulling the case because it may break the motherboard.
  11. Asus Vivobook Max X541SA-PD0703X Battery Replacement: 11 단계, 이미지 2개 중 1개 Asus Vivobook Max X541SA-PD0703X Battery Replacement: 11 단계, 이미지 2개 중 2개
    • There is a wire attached to the screen display.
    • Peel the sticker and disconnect it from the motherboard.
  12. Asus Vivobook Max X541SA-PD0703X Battery Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the plastic covering off of the motherboard.
  13. Asus Vivobook Max X541SA-PD0703X Battery Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the five 6mm Phillips #0 screws from the motherboard.
  14. Asus Vivobook Max X541SA-PD0703X Battery Replacement: 14 단계, 이미지 2개 중 1개 Asus Vivobook Max X541SA-PD0703X Battery Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the cables connected to the motherboard by unplugging them using a plastic opening tool, or by hand.
  15. Asus Vivobook Max X541SA-PD0703X Battery Replacement: 15 단계, 이미지 1개 중 1개
    • Pull the motherboard to the right and lift up.
  16. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Battery: 16 단계, 이미지 1개 중 1개
    • Remove the 6mm Phillips #0 screw from the battery bracket.
  17. Asus Vivobook Max X541SA-PD0703X Battery Replacement: 17 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to remove the battery from the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hetvi Mehta
회원 가입일: 02/22/18
781 평판
안내서 5개를 작성함
USF Tampa, Team S1-G4, Cagle Spring 2018 USF Tampa, Team S1-G4, Cagle Spring 2018 회원
USFT-CAGLE-S18S1G4
4 회원들
안내서 7개를 작성함
4가이드 댓글
Finished so simple, guide was easy to follow. Thank you
Forever R Holdings - 답글
Who was the idiot who designed this laptop? Remove the motherboard to replace the battery? Unbelievable.
Greg Worrel - 답글
I have a dead cmos battery and it seems i need to replace the whole battery
Wint3r xxx -
Sir how do I replace my cmos battery? Is it integrated with the battery. I also have Asus Vivobook Max X541SA-PD0703X
Wint3r xxx - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 43
전체 시간: 5,571
