주요 콘텐츠로 건너뛰기
Asus Vivobook Max X541SA-PD0703X Motherboard Replacement
필요한 것
  1. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 3 단계, 이미지 1/3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 3 단계, 이미지 2/3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 3 단계, 이미지 3/3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 4 단계, 이미지 1/3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 4 단계, 이미지 2/3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 4 단계, 이미지 3/3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 6 단계, 이미지 1/2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 6 단계, 이미지 2/2
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
  8. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Disc Drive: 8 단계, 이미지 1/1
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
  9. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Motherboard: 9 단계, 이미지 1/2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Motherboard: 9 단계, 이미지 2/2
    • Remove the three 6mm Phillips #0 screws from the fan shroud.
    • Remove the shroud from the motherboard.
  10. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 10 단계, 이미지 1/1
    • Pull the metal casing to the right.
    • Be careful when pulling the case because it may break the motherboard.
  11. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 11 단계, 이미지 1/2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 11 단계, 이미지 2/2
    • There is a wire attached to the screen display.
    • Peel the sticker and disconnect it from the motherboard.
  12. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 12 단계, 이미지 1/1
    • Remove the plastic covering off of the motherboard.
  13. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 13 단계, 이미지 1/1
    • Remove the five 6mm Phillips #0 screws from the motherboard.
  14. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 14 단계, 이미지 1/2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 14 단계, 이미지 2/2
    • Remove the cables connected to the motherboard by unplugging them using a plastic opening tool, or by hand.
  15. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 15 단계, 이미지 1/1
    • Pull the motherboard to the right and lift up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Hetvi Mehta
회원 가입일: 02/22/18
781 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G4, Cagle Spring 2018 USF Tampa, Team S1-G4, Cagle Spring 2018 회원
USFT-CAGLE-S18S1G4
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 15
전체 시간: 3,103
