주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Vivobook Max X541SA-PD0703X Track Pad Replacement
필요한 것
  1. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: 3 단계, 이미지 2개 중 1개 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: 3 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, pry up the palm rest form the bottom half of the laptop.
    • Ribbon cables connect the two half so don't remove completely.
  4. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: 4 단계, 이미지 3개 중 1개 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: 4 단계, 이미지 3개 중 2개 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: 4 단계, 이미지 3개 중 3개
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: 5 단계, 이미지 1개 중 1개
    • Take the keyboard half of the laptop and place it in front of you so that they keys are facing down.
  6. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the three 3mm Phillips #0 screws from the touchpad.
  7. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: 7 단계, 이미지 1개 중 1개
    • Use a spudger to flip up the retaining flap on the touch pad ribbon cable ZIF socket.
    • Pull the ribbon out of the socket.
  8. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: 8 단계, 이미지 2개 중 1개 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the touchpad.
결론
작성자
4다른 기여자 명과 함께
Hetvi Mehta
회원 가입일: 02/22/18
781 평판
안내서 5개를 작성함
USF Tampa, Team S1-G4, Cagle Spring 2018 USF Tampa, Team S1-G4, Cagle Spring 2018 회원
USFT-CAGLE-S18S1G4
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 15
전체 시간: 586
