주요 콘텐츠로 건너뛰기
Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement
필요한 것
  1. Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement: 2 단계, 이미지 1/2 Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement: 2 단계, 이미지 2/2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement: 3 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement: 3 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement: 3 단계, 이미지 3/3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement: 4 단계, 이미지 1/1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 CMOS Battery Replacement, CMOS Battery: 5 단계, 이미지 1/1
    • Disconnect the CMOS battery and its wire from the connector. The CMOS battery is now disconnected from your device.
결론
Kevin Kochanek
회원 가입일: 11/06/18
181 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 19
전체 시간: 1,623
