주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Some signs of a possible hard drive failure may be frequent disk errors, crashes, or error messages while running software. This guide will show you how to replace a failing hard drive.
부품
지정된 부품이 없습니다.
  1. Make sure the computer is turned off.
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Remove the four 5mm Phillips #1 screws from the top of the laptop. Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Manta(만타) 드라이버 키트
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta(만타) 드라이버 키트
  4. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  5. Lift off the cover and remove the back cover from the device.
    • Lift off the cover and remove the back cover from the device.
  6. Slide the hard drive out of the SATA port and remove it from the device.
    • Slide the hard drive out of the SATA port and remove it from the device.
결론
Samuel Foster
회원 가입일: 2018년 11월 06일
157 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G3
3 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 233
