주요 콘텐츠로 건너뛰기
Asus Vivobook Q301LA-BHI5T02 RAM Replacement
필요한 것
  1. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement, Back Cover: 1 단계, 이미지 1/1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: 2 단계, 이미지 1/2 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: 2 단계, 이미지 2/2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: 3 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: 3 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: 3 단계, 이미지 3/3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: 4 단계, 이미지 1/1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement, RAM: 5 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement, RAM: 5 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement, RAM: 5 단계, 이미지 3/3
    • Remove the top covering the RAM chips.
  6. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: 6 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: 6 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: 6 단계, 이미지 3/3
    • Gently push the RAM chip holder to the sides.
  7. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: 7 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: 7 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: 7 단계, 이미지 3/3
    • Remove the RAM from the device.
결론
Jorge Villarreal
회원 가입일: 10/02/17
397 평판
안내서 3개 작성하였습니다
USF Tampa, Team S10-G3, Thompson Fall 2017 USF Tampa, Team S10-G3, Thompson Fall 2017 회원
USFT-THOMPSON-F17S10G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 709
