주요 콘텐츠로 건너뛰기
Asus Vivobook Q301LA-BHI5T02 Screen Replacement
필요한 것
  1. Asus Vivobook Q301LA-BHI5T02 Screen Replacement, Back Cover: 1 단계, 이미지 1/1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 2 단계, 이미지 1/2 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 2 단계, 이미지 2/2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 3 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 3 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 3 단계, 이미지 3/3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 4 단계, 이미지 1/1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 Screen Replacement, Screen: 5 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement, Screen: 5 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement, Screen: 5 단계, 이미지 3/3
    • Unplug the screen connector from the motherboard.
  6. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 6 단계, 이미지 1/2 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 6 단계, 이미지 2/2
    • Using a Phillips #1 Screwdriver unscrew the four 4 mm screws holding the screen holder onto the motherboard.
  7. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 7 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 7 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 7 단계, 이미지 3/3
    • Remove the two cables connecting to the wifi card.
  8. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 8 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 8 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 8 단계, 이미지 3/3
    • Remove the screen holder from the rest of the laptop.
    • Make sure when removing screen cover lift bottom of the laptop to about a 45° degree angle when removing it.
  9. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 9 단계, 이미지 1/2 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 9 단계, 이미지 2/2
    • Remove the bottom of the laptop from the screen.
  10. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 10 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 10 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 10 단계, 이미지 3/3
    • Remove the hinge cover by gently pulling to the right then upwards.
  11. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 11 단계, 이미지 1/1
    • Using a Phillips #1 Screwdriver unscrew the six 3 mm black screws and the three 2 mm copper screws that are keeping the screen in place.
    • Keep track of what screws go where.
  12. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 12 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 12 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 12 단계, 이미지 3/3
    • Push screen downwards then pull top of screen upwards and remove the screen.
  13. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 13 단계, 이미지 1/2 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 13 단계, 이미지 2/2
    • Using a Phillips #1 Screwdriver Unscrew the four 2 mm screws holding the screen onto the screen cover.
    • Use the PH0 bit screwdriver to unscrew the screws.
  14. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 14 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 14 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 14 단계, 이미지 3/3
    • Use a sharp object to remove tape from the back of the screen.
    • Careful when cutting the tape off, you can accidentally cut a wire
  15. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 15 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 15 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 15 단계, 이미지 3/3
    • Unplug the screen from the screen holder.
    • Don't pull the cable too hard or it can damage the connection.
  16. Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 16 단계, 이미지 1/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 16 단계, 이미지 2/3 Asus Vivobook Q301LA-BHI5T02 Screen Replacement: 16 단계, 이미지 3/3
    • Take the screen off of the screen holder.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jorge Villarreal
회원 가입일: 10/02/17
397 평판
안내서 3개 작성하였습니다
USF Tampa, Team S10-G3, Thompson Fall 2017 USF Tampa, Team S10-G3, Thompson Fall 2017 회원
USFT-THOMPSON-F17S10G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 20
30일 전: 28
전체 시간: 3,450
