주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide will show the reader how to replace their failing USB Port Plate with a new one. If devices plugged into the USB ports aren't connecting properly, the plate may need to be replaced.
부품
지정된 부품이 없습니다.
  1. Make sure the computer is turned off.
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Remove the four 5mm Phillips #1 screws from the top of the laptop. Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place. Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  5. Lift off the cover and remove the back cover from the device.
    • Lift off the cover and remove the back cover from the device.
  6. Slide the hard drive out of the SATA port and remove it from the device.
    • Slide the hard drive out of the SATA port and remove it from the device.
  7. Remove the two 5.0 mm Phillips #1 screws shown.
    • Remove the two 5.0 mm Phillips #1 screws shown.
    • Remove the two 3.0 mm Phillips #1 screws shown.
  8. Using a plastic opening tool, pry open the hinge shown until your fingers can fit under it.
    • Using a plastic opening tool, pry open the hinge shown until your fingers can fit under it.
  9. Pull the hinge the rest of the way up.
    • Pull the hinge the rest of the way up.
  10. Disconnect the plate from the shown connector. The USB port plate is now disconnected from your device.
    • Disconnect the plate from the shown connector. The USB port plate is now disconnected from your device.
결론
Kevin Kochanek
회원 가입일: 2018년 11월 06일
181 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G3
3 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 84
