주요 콘텐츠로 건너뛰기
Asus Vivobook S500CA RAM Replacement
필요한 것
  1. Asus Vivobook S500CA RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Turn the device over so the back plate is facing up.
  2. Asus Vivobook S500CA RAM Replacement: 2 단계, 이미지 1/1
    • Use a Philips Head PH1 screwdriver to remove 10 screws around the perimeter of the back plate.
    • Place screws where they cannot be lost as they will be used to replace the back plate.
  3. Asus Vivobook S500CA RAM Replacement: 3 단계, 이미지 1/1
    • Remove the back plate by lifting it straight up.
  4. Asus Vivobook S500CA RAM Replacement: 4 단계, 이미지 1/1
    • Push away the tabs on the left and right sides of the RAM cartridge to release the cartridge.
    • Another pair of hands will make the process easier.
  5. Asus Vivobook S500CA RAM Replacement: 5 단계, 이미지 1/2 Asus Vivobook S500CA RAM Replacement: 5 단계, 이미지 2/2
    • Slide the cartridge directly away from its housing.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Sydney Price
회원 가입일: 01/17/17
264 평판
안내서 2개 작성하였습니다
댓글 한 개
You did not replace the RAM, nor give specifications on what RAM to replace it with (DDR3 1600 SDRAM DIMM etc)
Especially as it does not look like normal laptop memory (SODIMM)
facebook - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 22
전체 시간: 3,244
