주요 콘텐츠로 건너뛰기
Asus Vivobook S500CA Screen Hinges Replacement
필요한 것
  1. Asus Vivobook S500CA Screen Hinges Replacement, Screen Hinges: 1 단계, 이미지 1/1
    • Turn the device over so the back plate is facing up.
  2. Asus Vivobook S500CA Screen Hinges Replacement: 2 단계, 이미지 1/1
    • Use a Phillips Head PH1 screwdriver to remove 10 screws around the perimeter of the back plate.
    • It may be helpful to lay out the screws in the orientation in which they are taken out, in order to help remember where they go.
  3. Asus Vivobook S500CA Screen Hinges Replacement: 3 단계, 이미지 1/1
    • Remove the back plate by lifting it straight up.
  4. Asus Vivobook S500CA Screen Hinges Replacement: 4 단계, 이미지 1/2 Asus Vivobook S500CA Screen Hinges Replacement: 4 단계, 이미지 2/2
    • Remove 3 (.5 cm) phillips screws around the edge of the hinge. Repeat for other side.
  5. Asus Vivobook S500CA Screen Hinges Replacement: 5 단계, 이미지 1/1
    • Disconnect the black and white wires from the “Aux” (white) and “Main” (black) ports
  6. Asus Vivobook S500CA Screen Hinges Replacement: 6 단계, 이미지 1/2 Asus Vivobook S500CA Screen Hinges Replacement: 6 단계, 이미지 2/2
    • Open the device to access the plastic casing over the hinges.
    • Remove the casing by lifting firmly. This step can be difficult.
  7. Asus Vivobook S500CA Screen Hinges Replacement: 7 단계, 이미지 1/2 Asus Vivobook S500CA Screen Hinges Replacement: 7 단계, 이미지 2/2
    • Remove 4 (.5 cm) screws from the hinge. Remove the hinge and follow steps in reverse order to reassemble and complete repair.
결론
Jermaine Carnell
회원 가입일: 01/17/17
107 평판
안내서 1개 작성함
댓글 한 개
Hi.
The Asus X550C set screen (screen + flat cable) is compatible with Asus S500CA notebook? Anybody know response for me? Tks
Rodrigo Rodrigues - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 10
전체 시간: 2,346
