주요 콘텐츠로 건너뛰기
Asus Vivobook S500CA Touch Pad Replacement
필요한 것
  1. Asus Vivobook S500CA Touch Pad Replacement, Touch Pad: 1 단계, 이미지 1/1
    • Turn the device over so the back plate is facing up.
  2. Asus Vivobook S500CA Touch Pad Replacement: 2 단계, 이미지 1/1
    • Use a Philips Head PH1 screwdriver to remove 10 screws (3 10mm screws and 7 5mm screws) around the perimeter of the back plate.
  3. Asus Vivobook S500CA Touch Pad Replacement: 3 단계, 이미지 1/1
    • Remove the back plate by lifting it straight up.
  4. Asus Vivobook S500CA Touch Pad Replacement: 4 단계, 이미지 1/1
    • Remove 9 5mm screws around the edge of the battery
  5. Asus Vivobook S500CA Touch Pad Replacement: 5 단계, 이미지 1/1
    • Lift up the battery to reveal the battery terminal.
  6. Asus Vivobook S500CA Touch Pad Replacement: 6 단계, 이미지 1/1
    • Unclip the battery terminal by prying straight up on the sides of the connector to release the clips.
  7. Asus Vivobook S500CA Touch Pad Replacement: 7 단계, 이미지 1/1
    • Remove the silver tape at the edge of the touch pad.
  8. Asus Vivobook S500CA Touch Pad Replacement: 8 단계, 이미지 1/1
    • Disconnect the white ribbon labeled “TP” by pulling gently.
  9. Asus Vivobook S500CA Touch Pad Replacement: 9 단계, 이미지 1/1
    • Remove 2 5mm screws from the hard drive casing.
  10. Asus Vivobook S500CA Touch Pad Replacement: 10 단계, 이미지 1/1
    • Slide the touch pad out.
결론
Sydney Price
회원 가입일: 01/17/17
264 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 646
