주요 콘텐츠로 건너뛰기
Asus W2W-A1 Speaker Replacement
필요한 것
  1. Asus W2W-A1 Speaker Replacement, Keyboard: 1 단계, 이미지 1/3 Asus W2W-A1 Speaker Replacement, Keyboard: 1 단계, 이미지 2/3 Asus W2W-A1 Speaker Replacement, Keyboard: 1 단계, 이미지 3/3
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
  2. Asus W2W-A1 Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the panel above the keyboard with a plastic spudger.
  3. Asus W2W-A1 Speaker Replacement: 3 단계, 이미지 1/1
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  4. Asus W2W-A1 Speaker Replacement: 4 단계, 이미지 1/2 Asus W2W-A1 Speaker Replacement: 4 단계, 이미지 2/2
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
  5. Asus W2W-A1 Speaker Replacement, Front Panel: 5 단계, 이미지 1/1
    • Place your fingers or a spudger between the front panel and the rest of the laptop.
    • Pull upwards gently to detach the side you are grabbing.
    • Repeat on the other side until the panel easily peels off the laptop.
  6. Asus W2W-A1 Speaker Replacement, Touchpad: 6 단계, 이미지 1/2 Asus W2W-A1 Speaker Replacement, Touchpad: 6 단계, 이미지 2/2
    • The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
  7. Asus W2W-A1 Speaker Replacement: 7 단계, 이미지 1/1
    • Gently pull the ribbon cable out of its socket attached to the touchpad.
    • You are now able to remove the touchpad.
  8. Asus W2W-A1 Speaker Replacement, Protective Cover: 8 단계, 이미지 1/1
    • Unscrew the 3 13 mm Phillips screws on the surface of the panel.
    • Unscrew the 4 mm Phillips screw beneath the panel.
  9. Asus W2W-A1 Speaker Replacement: 9 단계, 이미지 1/3 Asus W2W-A1 Speaker Replacement: 9 단계, 이미지 2/3 Asus W2W-A1 Speaker Replacement: 9 단계, 이미지 3/3
    • There are many different types of screws in this step so make sure to arrange the screws by their different sizes.
    • Unscrew the six 17 mm Phillips head screws on the stands on the back and the 2 "A" screws of the same size adjacent to the stands.
    • Unscrew the two C Phillips head screws on the hard drive panel. There is also one more C screw in the upper right corner of the laptop as shown.
    • Unscrew the eight 8mm lock phillips screws and the screws along the outside of the laptop.
    • Unscrew the three 3mm E Phillips screw and the one 3mm D Phillips screw.
    • Unscrew the 5mm Phillips head screw that lies just above the D screw.
  10. Asus W2W-A1 Speaker Replacement: 10 단계, 이미지 1/1
    • Unscrew the two 8 mm Phillips screws beneath the hard drive panel.
    • After finishing this step, flip the laptop over.
  11. Asus W2W-A1 Speaker Replacement: 11 단계, 이미지 1/1
    • Everything should now be loose enough for you to start removing the panel.
    • Do not fully remove the panel, for there are still ribbons attached on the inside.
  12. Asus W2W-A1 Speaker Replacement: 12 단계, 이미지 1/1
    • Carefully remove the ribbons from the base.
    • Then you can lift the panel to access the components beneath.
  13. Asus W2W-A1 Speaker Replacement, Speaker: 13 단계, 이미지 1/3 Asus W2W-A1 Speaker Replacement, Speaker: 13 단계, 이미지 2/3 Asus W2W-A1 Speaker Replacement, Speaker: 13 단계, 이미지 3/3
    • Remove the 2 4 mm, wide Phillips screws per speaker holding in the two speakers at the lower end of the device.
  14. Asus W2W-A1 Speaker Replacement: 14 단계, 이미지 1/1
    • Lift up the speakers to separate from the device.
    • The speakers are connected to the device by a cable. Be careful not to rip this off.
  15. Asus W2W-A1 Speaker Replacement: 15 단계, 이미지 1/2 Asus W2W-A1 Speaker Replacement: 15 단계, 이미지 2/2
    • Grab the cable by the white connection to the laptop, and gently pull to disconnect.
결론
Nolan Schock
회원 가입일: 04/14/14
501 평판
안내서 5개 작성하였습니다
Cal Poly, Team 13-29, Maness Spring 2014 Cal Poly, Team 13-29, Maness Spring 2014 회원
CPSU-MANESS-S14S13G29
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 197
