주요 콘텐츠로 건너뛰기
Asus W2W-A1 Touchpad Replacement
필요한 것
  1. Asus W2W-A1 Touchpad Replacement, Keyboard: 1 단계, 이미지 1/3 Asus W2W-A1 Touchpad Replacement, Keyboard: 1 단계, 이미지 2/3 Asus W2W-A1 Touchpad Replacement, Keyboard: 1 단계, 이미지 3/3
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
  2. Asus W2W-A1 Touchpad Replacement: 2 단계, 이미지 1/1
    • Remove the panel above the keyboard with a plastic spudger.
  3. Asus W2W-A1 Touchpad Replacement: 3 단계, 이미지 1/1
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  4. Asus W2W-A1 Touchpad Replacement: 4 단계, 이미지 1/2 Asus W2W-A1 Touchpad Replacement: 4 단계, 이미지 2/2
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
  5. Asus W2W-A1 Touchpad Replacement, Front Panel: 5 단계, 이미지 1/1
    • Place your fingers or a spudger between the front panel and the rest of the laptop.
    • Pull upwards gently to detach the side you are grabbing.
    • Repeat on the other side until the panel easily peels off the laptop.
  6. Asus W2W-A1 Touchpad Replacement, Touchpad: 6 단계, 이미지 1/2 Asus W2W-A1 Touchpad Replacement, Touchpad: 6 단계, 이미지 2/2
    • The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
  7. Asus W2W-A1 Touchpad Replacement: 7 단계, 이미지 1/1
    • Gently pull the ribbon cable out of its socket attached to the touchpad.
    • You are now able to remove the touchpad.
결론
Nolan Schock
회원 가입일: 04/14/14
501 평판
안내서 5개 작성하였습니다
Cal Poly, Team 13-29, Maness Spring 2014 Cal Poly, Team 13-29, Maness Spring 2014 회원
CPSU-MANESS-S14S13G29
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 240
