주요 콘텐츠로 건너뛰기
Asus X200CA Battery Replacement
필요한 것
  1. Asus X200CA Battery Replacement, Keyboard: 1 단계, 이미지 1/2 Asus X200CA Battery Replacement, Keyboard: 1 단계, 이미지 2/2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Battery Replacement: 2 단계, 이미지 1/1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Battery Replacement: 3 단계, 이미지 1/1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Battery Replacement, Battery: 4 단계, 이미지 1/2 Asus X200CA Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the black 4.7mm screw holding the battery in place.
  5. Asus X200CA Battery Replacement: 5 단계, 이미지 1/1
    • Lift the battery by the tab you removed the screw from.
    • Replace with the new battery, if necessary.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Jacqueline Collier
회원 가입일: 10/09/17
1,047 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G2, Leahy Fall 2017 USF Tampa, Team S1-G2, Leahy Fall 2017 회원
USFT-LEAHY-F17S1G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 29
전체 시간: 6,926
