소개
This guide will show you how to replace the battery of the Asus X200CA. The battery is a 3Cells 3300 mAh 33 Whrs.
필요한 것
Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
Remove the black 14.5mm screw from the center of the bottom cover.
Use a Phillips #00 screwdriver to remove the black 4.7mm screw holding the battery in place.
거의 끝나갑니다!
결론
다른 11명이 해당 안내서를 완성하였습니다.
