주요 콘텐츠로 건너뛰기
Asus X200CA Motherboard and RAM Replacement
필요한 것
  1. Asus X200CA Motherboard and RAM Replacement, Keyboard: 1 단계, 이미지 1/2 Asus X200CA Motherboard and RAM Replacement, Keyboard: 1 단계, 이미지 2/2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Motherboard and RAM Replacement: 2 단계, 이미지 1/1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Motherboard and RAM Replacement: 3 단계, 이미지 1/1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Motherboard and RAM Replacement, Motherboard and RAM: 4 단계, 이미지 1/1
    • Remove the black plastic cover.
  5. Asus X200CA Motherboard and RAM Replacement: 5 단계, 이미지 1/2 Asus X200CA Motherboard and RAM Replacement: 5 단계, 이미지 2/2
    • Remove the 10 black 4.7mm screws holding the motherboard/RAM in place using a Phillips #00 screwdriver.
  6. Asus X200CA Motherboard and RAM Replacement: 6 단계, 이미지 1/2 Asus X200CA Motherboard and RAM Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to separate the 2 sliding connectors and the ribbon cable connector.
  7. Asus X200CA Motherboard and RAM Replacement: 7 단계, 이미지 1/2 Asus X200CA Motherboard and RAM Replacement: 7 단계, 이미지 2/2
    • Use fingers to grab the black tape tab and pull back to disconnect the battery connector.
  8. Asus X200CA Motherboard and RAM Replacement: 8 단계, 이미지 1/1
    • Lift the motherboard/RAM out from the frame.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jacqueline Collier
회원 가입일: 10/09/17
1,047 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G2, Leahy Fall 2017 USF Tampa, Team S1-G2, Leahy Fall 2017 회원
USFT-LEAHY-F17S1G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 100
전체 시간: 8,852
