주요 콘텐츠로 건너뛰기
Asus X200CA-HCL 1104G Fan Replacement
필요한 것
  1. Asus X200CA-HCL 1104G Fan Replacement, Fan: 1 단계, 이미지 1개 중 1개
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Fan Replacement: 2 단계, 이미지 1개 중 1개
    • The fan will be visible toward the bottom of the internals. It is semicircular with a small wire connected to the top of it.
    • Visually inspect the fan for any debris or blockage. If there is none, the fan probably needs to be replaced. To do that, we need to first disconnect the fan from the computer.
  3. Asus X200CA-HCL 1104G Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the fan by gently pulling the connectors on the wire apart from each other.
  4. Asus X200CA-HCL 1104G Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Now, use the Phillips 1 screwdriver to unfasten the two screws holding the fan in place.
    • From here, the fan will lift easily out of the laptop.
결론
작성자
2다른 기여자 명과 함께
Samantha Wahl
회원 가입일: 10/17/17
301 평판
안내서 3개를 작성함
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 UMass Dartmouth, Team S1-G2, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G2
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 293
