주요 콘텐츠로 건너뛰기
Asus X200CA-HCL 1104G Headphone Jack Replacement
필요한 것
  1. Asus X200CA-HCL 1104G Headphone Jack Replacement, Headphone Jack: 1 단계, 이미지 1/1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Headphone Jack Replacement: 2 단계, 이미지 1/1
    • Now, locate the audio board. This model has an L-shaped board. It can be found in the far left region of the internals.
  3. Asus X200CA-HCL 1104G Headphone Jack Replacement: 3 단계, 이미지 1/1
    • Firstly, disconnect the two tiny wires that connect the audio board to other components. They can be found on a black square near the green decoder strip. Remember to be gentle with these delicate components.
  4. Asus X200CA-HCL 1104G Headphone Jack Replacement: 4 단계, 이미지 1/2 Asus X200CA-HCL 1104G Headphone Jack Replacement: 4 단계, 이미지 2/2
    • Using the Phillips 1 screwdriver, remove the six screws that hold the audio board in place.
    • Hint: the sixth screw may not be readily visible. It can be found in the bottom left corner of the audio board, under a small black flap.
    • With the screws removed, the audio board can be easily lifted out.
결론
Samantha Wahl
회원 가입일: 10/17/17
301 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 UMass Dartmouth, Team S1-G2, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 123
