주요 콘텐츠로 건너뛰기
Asus X200CA-HCL 1104G Motherboard Replacement
필요한 것
  1. Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • Pry open the Keyboard/Touch pad.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  2. Asus X200CA-HCL 1104G Motherboard Replacement: 2 단계, 이미지 1/1
    • Detach keyboard and touch screen cables
    • These are the cable that are holding the keyboard and touch screen together
  3. Asus X200CA-HCL 1104G Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the following four screws: Four 4 mm Phillips #0 using a phillips screwdriver.
    • Slide out the hard drive
  4. Asus X200CA-HCL 1104G Motherboard Replacement: 5 단계, 이미지 1/1
    • Detach speaker
  5. Asus X200CA-HCL 1104G Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove motherboard screws
    • These would be located on the green panel which is the motherboard
    • Carefully remove motherboard
결론
Svetlana Pimentel
회원 가입일: 10/17/17
201 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 UMass Dartmouth, Team S1-G2, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 394
