주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus X200MA Battery Replacement
필요한 것
  1. Asus X200MA Battery Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Battery Replacement, Battery: 4 단계, 이미지 1개 중 1개
  5. Asus X200MA Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Slide the battery up and out.
결론
다른 30명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Vanessa Garcia
회원 가입일: 01/22/15
1,796 평판
안내서 6개를 작성함
Cal Poly, Team 21-24, Maness Winter 2015 Cal Poly, Team 21-24, Maness Winter 2015 회원
CPSU-MANESS-W15S21G24
4 회원들
안내서 8개를 작성함
8가이드 댓글
Merci super!
Patricia Domalain - 답글 공유
Thanks for the write up! Easy to follow, Great photos, and worked great!
nathaniel forward - 답글 공유
thanks it worked
iqbal nasution - 답글 공유
Your step by step instructions were so easy to follow. Great job. Thanks! :)
Fernando H - 답글 공유
I would like to buy a battery to it, Please suggest me the best portal site
jagadeeshkumar maddala - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 16
지난 30일: 84
전체 시간: 36,779
