주요 콘텐츠로 건너뛰기
Asus X200MA Battery Replacement
필요한 것
  1. Asus X200MA Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Battery Replacement: 2 단계, 이미지 1/1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Battery Replacement: 3 단계, 이미지 1/1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Battery Replacement, Battery: 4 단계, 이미지 1/1
  5. Asus X200MA Battery Replacement: 5 단계, 이미지 1/1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Battery Replacement: 6 단계, 이미지 1/1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Battery Replacement: 7 단계, 이미지 1/1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Battery Replacement: 8 단계, 이미지 1/1
    • Slide the battery up and out.
결론
다른 29명이 해당 안내서를 완성하였습니다.
Vanessa Garcia
회원 가입일: 01/22/15
1,763 평판
안내서 6개 작성하였습니다
Cal Poly, Team 21-24, Maness Winter 2015 Cal Poly, Team 21-24, Maness Winter 2015 회원
CPSU-MANESS-W15S21G24
4 회원들
안내서 8개 작성하였습니다
댓글 8개
Thanks for the write up! Easy to follow, Great photos, and worked great!
nathaniel forward - 답글
Your step by step instructions were so easy to follow. Great job. Thanks! :)
Fernando H - 답글
I would like to buy a battery to it, Please suggest me the best portal site
jagadeeshkumar maddala - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 57
전체 시간: 35,473
