주요 콘텐츠로 건너뛰기
Asus X200MA Hard Drive Replacement
필요한 것
  1. Asus X200MA Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Hard Drive Replacement: 2 단계, 이미지 1/1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Asus X200MA Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Remove the black foam and adhesive located on top of the hard drive.
  4. Asus X200MA Hard Drive Replacement: 4 단계, 이미지 1/1
    • Remove the following four screws:
    • Four 4 mm Phillips #0 using a phillips screwdriver.
  5. Asus X200MA Hard Drive Replacement: 5 단계, 이미지 1/1
    • Slide out the hard drive
결론
다른 3명이 해당 안내서를 완성하였습니다.
Vanessa Garcia
회원 가입일: 01/22/15
1,763 평판
안내서 6개 작성하였습니다
Cal Poly, Team 21-24, Maness Winter 2015 Cal Poly, Team 21-24, Maness Winter 2015 회원
CPSU-MANESS-W15S21G24
4 회원들
안내서 8개 작성하였습니다
댓글 2개
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
Matthew Miller - 답글
Very poor!!! If you follow this instruction, you will destroy your Laptop. I did nearly destroying it. You did not show the 2 screws under the rubbers.
Minus 1000 points!!!
luft_ha - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 9,143
