주요 콘텐츠로 건너뛰기
Asus X200MA Motherboard Replacement
필요한 것
  1. Asus X200MA Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Motherboard Replacement: 2 단계, 이미지 1/1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Asus X200MA Motherboard Replacement, Battery: 3 단계, 이미지 1/1
    • Take two rubber caps off the back side of the laptop.
  4. Asus X200MA Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  5. Asus X200MA Motherboard Replacement: 5 단계, 이미지 1/1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  6. Asus X200MA Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  7. Asus X200MA Motherboard Replacement: 7 단계, 이미지 1/1
    • Slide the battery up and out.
  8. Asus X200MA Motherboard Replacement, Fan: 8 단계, 이미지 1/1
    • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
  9. Asus X200MA Motherboard Replacement: 9 단계, 이미지 1/2 Asus X200MA Motherboard Replacement: 9 단계, 이미지 2/2
    • Unplug the set of wires located at bottom corner on fan.
  10. Asus X200MA Motherboard Replacement: 10 단계, 이미지 1/2 Asus X200MA Motherboard Replacement: 10 단계, 이미지 2/2
    • Lift up and out to completely the remove fan component.
  11. Asus X200MA Motherboard Replacement, Motherboard: 11 단계, 이미지 1/1
    • Use Phillips #0 screwdriver to remove the eight 4.0 mm screws.
  12. Asus X200MA Motherboard Replacement: 12 단계, 이미지 1/2 Asus X200MA Motherboard Replacement: 12 단계, 이미지 2/2
    • Pull back the blue ribbon, freeing it from the latch.
  13. Asus X200MA Motherboard Replacement: 13 단계, 이미지 1/3 Asus X200MA Motherboard Replacement: 13 단계, 이미지 2/3 Asus X200MA Motherboard Replacement: 13 단계, 이미지 3/3
    • Lift and pull the motherboard out from the hard drive and remove it from the base plate.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alli Krininger
회원 가입일: 11/11/19
391 평판
안내서 3개 작성하였습니다
IUPUI, Team S2-G4, Stella Fall 2019 IUPUI, Team S2-G4, Stella Fall 2019 회원
IUPUI-STELLA-F19S2G4
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 1,072
