주요 콘텐츠로 건너뛰기
Asus X200MA Speaker Replacement
필요한 것
  1. Asus X200MA Speaker Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Speaker Replacement: 2 단계, 이미지 1/1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Asus X200MA Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Disconnect the gold cap that connects to a black wire using the metal spudger.
  4. Asus X200MA Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the plastic component from the clip by gently pulling it back.
  5. Asus X200MA Speaker Replacement: 5 단계, 이미지 1/2 Asus X200MA Speaker Replacement: 5 단계, 이미지 2/2
    • Use the tweezers to free the speaker from the plastic clips.
    • Use a finger to lift the speaker and break the bond between the adhesive on the base plate and the speaker.
  6. Asus X200MA Speaker Replacement: 6 단계, 이미지 1/3 Asus X200MA Speaker Replacement: 6 단계, 이미지 2/3 Asus X200MA Speaker Replacement: 6 단계, 이미지 3/3
    • Use the tweezers to carefully lift the wires from the plastic clips.
  7. Asus X200MA Speaker Replacement: 7 단계, 이미지 1/2 Asus X200MA Speaker Replacement: 7 단계, 이미지 2/2
    • Use the metal tweezers to free the speaker from the plastic clips.
    • Use the metal spudger to break the bond between the base plate adhesive and the speaker.
    • Lift the speakers and remove them from the base plate.
결론
To reassemble your device, follow these instructions in reverse [#|order].
Alli Krininger
회원 가입일: 11/11/19
391 평판
안내서 3개 작성하였습니다
IUPUI, Team S2-G4, Stella Fall 2019 IUPUI, Team S2-G4, Stella Fall 2019 회원
IUPUI-STELLA-F19S2G4
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 464
