주요 콘텐츠로 건너뛰기
Asus X200MA Trackpad Replacement
필요한 것
  1. Asus X200MA Trackpad Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Trackpad Replacement: 2 단계, 이미지 1/1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Asus X200MA Trackpad Replacement, Trackpad: 3 단계, 이미지 1/2 Asus X200MA Trackpad Replacement, Trackpad: 3 단계, 이미지 2/2
    • Use the spudger to lift up and remove the black plastic covering.
  4. Asus X200MA Trackpad Replacement: 4 단계, 이미지 1/1
    • Remove thinner white strip by first flipping up black piece at the top of the strip with the tweezers and then pulling it out.
  5. Asus X200MA Trackpad Replacement, Mouse: 5 단계, 이미지 1/1
    • Remove wider blue strip with tweezers.
  6. Asus X200MA Trackpad Replacement: 6 단계, 이미지 1/1
    • Remove the following eight screws:
    • Eight 3 mm screws using Phillips #0 screwdriver.
  7. Asus X200MA Trackpad Replacement: 7 단계, 이미지 1/1
    • Remove the following two screws after lifting metal plate off:
    • Two 2 mmm screws using a Phillips #0 screwdriver.
  8. Asus X200MA Trackpad Replacement: 8 단계, 이미지 1/2 Asus X200MA Trackpad Replacement: 8 단계, 이미지 2/2
    • Use metal spudger to get in between mouse pad and keyboard and lift off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Vanessa Garcia
회원 가입일: 01/22/15
1,763 평판
안내서 6개 작성하였습니다
Cal Poly, Team 21-24, Maness Winter 2015 Cal Poly, Team 21-24, Maness Winter 2015 회원
CPSU-MANESS-W15S21G24
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 2,058
