이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
Take two rubber caps off the back side of the laptop.
Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
이 단계에 사용된 도구:Tweezers$4.99-
Remove thinner white strip by first flipping up black piece at the top of the strip with the tweezers and then pulling it out.
Remove the following eight screws:
Eight 3 mm screws using Phillips #0 screwdriver.
Remove the following two screws after lifting metal plate off:
Two 2 mmm screws using a Phillips #0 screwdriver.
Use metal spudger to get in between mouse pad and keyboard and lift off.
다른 한 분이 해당 안내서를 완성하였습니다.
