주요 콘텐츠로 건너뛰기
Asus X202E-UH31T Battery Replacement
필요한 것
  1. Asus X202E-UH31T Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the 9 1.2mm phillips head screws on the bottom of the computer using a small Phillips head screw driver.
  2. Asus X202E-UH31T Battery Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to open the components of the laptop. In order to do this, insert the plastic opening tool in between the two covers then pry open.
  3. Asus X202E-UH31T Battery Replacement: 3 단계, 이미지 1/1
    • Once the back is off the device, unscrew the 7 1.2mm phillips head screws that hold the battery in place using a small phillips head screw driver
  4. Asus X202E-UH31T Battery Replacement: 4 단계, 이미지 1/1
    • Once the screws holding the battery are out, use the plastic opening tool to disconnect the battery cable ribbon from the motherboard
  5. Asus X202E-UH31T Battery Replacement: 5 단계, 이미지 1/1
    • After replacing the battery, attach the wire ribbon to the motherboard and screw the designated screws back into the battery to secure it
결론
To reassemble your device, follow these steps in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Brandon Bloomfield
회원 가입일: 09/08/17
523 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 1,415
