주요 콘텐츠로 건너뛰기
Asus X202E-UH31T Ethernet Port Replacement
필요한 것
  1. Asus X202E-UH31T Ethernet Port  Replacement, Ethernet Port: 1 단계, 이미지 1/1
    • Remove the 9 1.2mm phillips head screws on the bottom of the computer using a small Phillips head screw driver.
  2. Asus X202E-UH31T Ethernet Port  Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to open the components of the laptop. In order to do this, insert the plastic opening tool in between the two covers then pry open with your fingers
  3. Asus X202E-UH31T Ethernet Port  Replacement: 3 단계, 이미지 1/2 Asus X202E-UH31T Ethernet Port  Replacement: 3 단계, 이미지 2/2
    • Remove the 4 1.2mm phillips head screws with a small phillips head screw driver that held the Ethernet port in place.
    • Lift and remove the Ethernet port
결론
Brandon Bloomfield
회원 가입일: 09/08/17
523 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 8
전체 시간: 300
